jamaicajohn82
Philippines
After I restored the factory defaults to my Mavic Pro it will no longer connect to the computer or remote. When I plug it back in with the same cable I have been using for weeks, it cycles on and off every second and won't connect to the computer. I have changed the cable to a new one. I have switched to a fully charged battery. I have removed the SD card. I have turned the computer and the drone on and off several times. And even worse, the drone will not connect with the remote control anymore. DJI Assistant 2 says the remote has version 01.03.0700 and that's what I wanted to also load into my drone. But first I restored the Factory Defaults to the drone using DJI Assistant 2 to load them successfully into the drone but then it immediately started cycling on and off and could no longer be reached through the computer or the remote. I want to load the same release 01.03.0700 into my drone but it won't even connect to the computer. The same cable connects other devices and it previously worked with the drone and I have tried other cables. Please help.
