New Phantom 4 RTK Firmware Released(2019/05/07)
5029 24 2019-5-7
DJI Support
Flight distance : 2408 ft
China
Overview
  • Date:        2019.05.07
  • Aircraft Firmware:        v02.01.0009
  • Remote Controller Firmware:        v02.01.0009
  • DJI GS RTK App:        v2.0.4
  • DJI Assistant 2 For Phantom:        v2.0.7
  • DJI Assistant 2 For MG:        v2.0.13
What’s New?
  • Added the 3D Photogrammetry (Multi-oriented) operation type. After planning the operation area, the generated flight routes will include a single orthographic flight route and four oblique flight routes.
  • Added the Terrain Awareness Mode operation type. To plan a Terrain Awareness operation, create a folder in the DJI\DSM path in the root directory of the microSD card, put tif and tfw files into it, and then import the files to the app. After planning flight route in the area corresponding to the imported files, the aircraft will follow the terrain when flying along the route.
  • Added notifications for abnormal Intelligent Flight Battery level. If abnormal battery level is detected, there will be a prompt in the app and RTH will be triggered.
  • Optimized the flight route planning for Linear Flight operations. Enable or disable “Flight route generated along center line” in the settings to determine whether the generated flight route will include the center line added when planning the operation.
  • Fixed the issue of slow task list loading.
  • Fixed the rare issue: there was camera preview image jitter during RTH.
  • Fixed issue: the remote controller firmware of the MG-1P and Phantom 4 RTK were not compatible with each other.
Notes:
  • This firmware includes Intelligent Flight Battery firmware. If you have multiple batteries, please run this firmware update on all of them.
  • The remote controller cannot be downgraded after this firmware update.
  • This firmware update may take a long time. Please wait and DO NOT power off the aircraft during updating.
  • Make sure that the firmware for both the aircraft and remote controller is up-to-date. Otherwise they will not work together.
2019-5-7
hummler
Flight distance : 13 ft
"Added the Terrain Awareness Mode operation type. To plan a Terrain Awareness operation, create a folder in the DJI\DSM path in the root directory of the microSD card, put tif and tfw files into it, and then import the files to the app. After planning flight route in the area corresponding to the imported files, the aircraft will follow the terrain when flying along the route."
This doesn't seem to work, the tif and tfw are not recognized. Do they have to be in a specific coordinate system, height system, raster spacing, file size...?
2019-5-8
dubik
Flight distance : 297054 ft
Poland
hummler Posted at 5-8 04:11
I have got same problem. Controler/transmitter can not impot tif and twf files from DJI\DSM directory. I checkt it with WGS84 cordinate system.
2019-5-8
djiuser_5TY7rX1lMZpe
Just got an answer from an DJI official: They are aware and try to fix the problems regarding the import of a DSM for Terrain Awareness Mode and the automatic language change to Chinese.
2019-5-8
Dragline49
djiuser_5TY7rX1lMZpe Posted at 5-8 05:39
Any new word on when DSM import will be working?
2019-5-10
strafly
Dragline49 Posted at 5-10 10:41
Someone uploaded a document that he got from someone working at DJI.
It worked for me. I was able to import a DEM. Just make sure that the DEM is in geographical coordinates, maybe not bigger than 100mb (did not test it) and create a folder structure like "/DSM/DJI/newtask" where you put in the .tfw and geotiff.
You will find the document here:
https://drive.google.com/file/d/17bWIHTD8yI3WI22kNsxWEV7mPys-g0Ww/view?fbclid=IwAR24g21kzNGN3CqVNLkEjn6p4uIyCZaqhCwR3BsXuRzQ0HVfi3VD2KNu-Ds
2019-5-13
JensB
Saudi Arabia
Hello,
how can I change the language back to English?
What is the advantage of terrain awareness mode?
Thanks
2019-5-15
strafly
JensB Posted at 5-15 04:54
Hello,
Language:
- Top left Corner, click on the three stripes
- click on the wheel (which is for "Settings")
- click on the bottom-most setting ("Android System Settings")
- scroll down to the "World"-symbol and click on it (Language)
- click on the top-most setting Language)
- choose "English"
Terrain awareness mode will let the drone follow the height of terrain according to your flight height.
2019-5-17
fans6a2d4df1
Flight distance : 410801 ft
We followed exactly the procedure and yet we fail to import the files, which are well in the SD card DJI / DSM / newtask
Can we help?
2019-5-20
strafly
fans6a2d4df1 Posted at 5-20 13:58
Can we help?
Hard to tell what causes your problem.
Maybe the size of your DSM or the coordinate system?
Did you make sure that it is below 100mb and in geographical coordiantes.
2019-5-23
MAHDI VAFI
Iran
HI
I UPDATE MY GS RTK APP AND UPLOAD DEM FILE FOR MY PROJECT TO RC BUT I WANT TO KNOW IT HOW ITS IMPOSSIBLE TO USE DEM FILE FOR LINEAR FLIGHT MISSION .
I UNDERSTAND THAT WE CAN USE DEM FILE ONLY FOR 2D PHOTOGRAMMETRY  MODE IN GS RTK APP .
THANKS.
2019-5-29
AntDX316
Flight distance : 2982907 ft
"This firmware includes Intelligent Flight Battery firmware. If you have multiple batteries, please run this firmware update on all of them."
Does this mean you should firmware refresh every battery??
2019-5-29
21harold21
Flight distance : 231709 ft
Peru
strafly Posted at 5-13 05:31
GRACIAS!!!!!!!!!!! me Sirvio!!!!
2019-5-30
strafly
MAHDI VAFI Posted at 5-29 14:16
HI
Linear Mission Planning and Terrain Follow do NOT work together at the moment. You can only choose between them. Suggested the same thing to DJI last week!
2019-6-6
strafly
21harold21 Posted at 5-30 21:04
You might also wanna look at this: https://www.aerotas.com/phantom-4-rtk-terrain-awareness?utm_source=Aerotas+Newsletter&utm_campaign=1d950d88e9-EMAIL_CAMPAIGN_2019_06_04_12_38&utm_medium=email&utm_term=0_2c3690a825-1d950d88e9-292057329
2019-6-6
albertdeguzman
Philippines
hi DJI, id like to know the security protocols and features of Phantom 4 that avoids hijacking or being hack on mid air.
2019-6-6
dan.blackmore
HI
How did you screenshot using the RTK controller?
2019-7-31
cetincelik
Flight distance : 56706 ft
Turkey
Hi, I want to upload kml file and make flight in terrain mode. it is very difficult to select the terrain model and mark the flight area manually from the screen. Is it possible to upload kml file after selecting terrain model? or how can I use kml file in terrain mode?
2019-8-1
cetincelik
Turkey
Hi, I want to upload kml file and make flight in terrain mode. it is very difficult to select the terrain model and mark the flight area manually from the screen. Is it possible to upload kml file after selecting terrain model? or how can I use kml file in terrain mode? Can I enter the corner coordinates of my flight area manually or from a computer in terrain mode?
2019-8-1
Gio RTK user
Problemone: ho l'RC con aggiornamento 0012 e il Ph4 RTK con aggiornamento 0009, e non c'è verso di portarli alla medesima release. ) né con upgrade, né con downgrade) E così non ho collegamento alla camera. Succede a qualcun'altro....? soluzioni possibili?
2019-8-29
Gio RTK user
cetincelik Posted at 8-1 01:42
I've got a problem: RC is updated on V02 01 0012 but the Ph4RTK in updated on V02 01 0009. O cannot upgrad or downgrade to have on both the same release.
Somebody has the same problem..... Solutions?
Thank you.
Giorgio Italy
2019-8-29
Gio RTK user
I've got a problem: RC is updated on V02 01 0012 but the Ph4RTK in updated on V02 01 0009. O cannot upgrad or downgrade to have on both the same release. Somebody has the same problem..... Solutions? Thank you. Giorgio Italy
2019-8-29
mbuonanno
Gio RTK user Posted at 8-29 12:34
Thank you.
Hi,
have you already tried to update the aircraft firmware using the remote controller + DJI GS RTK  instead of a PC and DJI Assistant 2 for Phantom?
Use the Micro-USB cable and USB Type-C OTG adapter to connect  the Phantom 4 RTK and use GS RTK app to download and update firmware for the remote controller and the aircraft.
see also:
https://forum.dji.com/forum.php? ... D699%26typeid%3D699
Fixed the issue where new firmware could not be downloaded in the DJI GS RTK app. When using an old version of the app, this issue can be fixed by: going to the main screen, tapping Menu, then Settings, Apply to All, Explorer, Internal Memory, and entering the path DJI\firm to delete the old firmware file.
Cheers,
Maurizio
2019-10-9
djiuser_7kkaReQFYq6W
hi,
since last week when I wanted to make a flight, an error message appeared 'ESC error communication'.The drone to fly only 5 times
The 4xESC are error. I did not suffer any crash or damage.
Can this be due to updates?
I have a lot of problem for upgrade firware.
2019-10-10
sputnik7
is there any explanation of how the 3D Photogrammetry (Multi-oriented) mode works ? i can find no information online and how it is different from the double grid...
also are there any plans for circular missions ? we use these a lot in combination with the double grid at the moment and is one of the main advantages of pix4d app at the momnent
2019-10-19
