hallmark007
Flight distance : 9812789 ft
You should have no problem sending to dji, it just depends on what is the service norm for your location, but although you might read some horror stories around here it’s certainly not the norm, if all paperwork is correct and you clearly explain the problem you should not have any problems or time constraints with time factor .
One thing you should know, it’s highly likely you will receive back either a new or refurbished as new craft, and this is what you should expect, dji seems to operate a system by sending your drone back to be refurbished while issuing you with a refurb or new craft.
Hopefully it will go smoothly for you , good luck . |
