DJI Matrice 210 RTK V2 X7 MAPPING DJI PILOT
5641 16 2019-5-12
Drönarkonsulten
Flight distance : 118944 ft
Sweden
Hi, when i try to use the Mapping function, my setups is not avilable, I run a M210 RTK v2 and an Zenmuse X7 with a 16mm lens. I can only chose from 24mm and above or other totaly diffrent setups.
I can choose custom, but i do not know what to put down in the setup?
Can anyone help me with this? if i use for example The x7 24mm setup my pictures looks totaly wrong...blury etc..
// Drönarkonsulten
2019-5-12
Drönarkonsulten
Sweden
Anyone? what setup to put in ? please?
2019-5-15
Keule
Flight distance : 3733015 ft
Drönarkonsulten Posted at 5-15 00:19
X7 Sensor:
size: 23.5 x 15.7 [mm]
resolution: 6016 x 4008 [pixel]
24 mm lens = (35 mm equiv.) 36 mm
2019-5-15
Drönarkonsulten
Sweden
Yes but what to put in to the pilot settings whenni choose mission flight and have to choose custom under cameras... thats what i looking for
Thnxs for the awnser!
2019-5-15
Keule
Drönarkonsulten Posted at 5-15 09:51
I am not quite sure what you mean ...
Did you create a custom camera with the settings before you use that newly created cam in your mission profile?
2019-5-15
Drönarkonsulten
Sweden
There are 2 premade for x7 but none has the 16mm lens... so i choose costum and does not know what to put down...
2019-5-15
Hi Drönarkonsulten, if you select Custom, you just need to input the actual focal length 16mm, other settings can refer to the specs of X7. If there is still no luck, could you please share us a screenshot?
2019-5-16
Drönarkonsulten
Sweden
Hi! This is what i get in front of me when i choose custom setup. What to put in were there is blue text? I have tje Zenmuse X7 and the M210 RTK V2.
Thanks for trying to help
2019-5-22
Drönarkonsulten
Sweden
Drönarkonsulten Posted at 5-22 08:54
Anyone has a setup for me here? for this Application?
2019-5-29
Drönarkonsulten
Sweden
Plz? I really need the help
2019-6-25
fans98f309a2
Flight distance : 2551063 ft
Drönarkonsulten Posted at 6-25 08:13
Hi ,  I would use for the X7 Sensor:
sensor size: w23.5 x h15.7 [mm]
resolution: width6016 x height4008 [pixel]
(like "Keule" said before..)
and use 16mm for focal length
I do not own the x7, but I do own the DJI 210 RTK v2 and use the X4s for mapping.(with mechanical shutter)
The x7 does support mechanical shutter (better for mapping)  but not in combination with the 16mm maybe thats why you can't find this lens it direct in the app.
I use GsPro (on Ipad) for mapping works fine with the new M210 RTK V2 (has also an option for the x7 ..)
If your pictures are blurry be sure to use high shutter times (1/500 , 1/640, or even higher if possible)
work only with manual settings (apurture/ shutter / iso) and also manual White balance (WB) choose sunny or cloudy.. depending on the weather of course...
Good luck!
2019-6-28
Drönarkonsulten
Sweden
fans98f309a2 Posted at 6-28 03:09
Thanks!!! I will try this ASAP!
2019-7-7
fansfbc25b9f
Drönarkonsulten Posted at 7-7 04:35
Did these settings work for you? I'm having the same problem now.
2019-7-10
Drönarkonsulten
Sweden
I put the settings in and it seems to work now. However now i get this
IMU initializing. Do not move aircraft until it completes. .... i tried all.. restore factory default, downgrade...manually IMU calibration (that states all is ok...) but still same message at start...no take of...
starting to regret this investment HARD
2019-7-19
BBerry
Flight distance : 67028 ft
Hello. I have the M210 V2. Would like to do some mapping with the X4S? Does any one know the resolution, focal length, etc for the parameters und custom camera in DJI Pilot app?
Thanks.
2019-8-10
DJI4Survey
Flight distance : 6484478 ft
I do not have the X4S (as much as I would like to), however, it is the same sensor as the Phantom 4 RTK, so just select it in the menu when flying the M210 with the X4S and I am sure it will work.
Let us know.
2020-1-14
DJI-BladeStrike
Flight distance : 872694 ft
The 16mm is not optimized nor does it have mechanical shutter. The only camera and lens that has been optimized with time sync are the 24mm and 35mm. 16mm is not supported and don't expect high accuracy.
2020-2-13
