Battery Grip Power Problems
1254 6 2019-5-12
sebustoned
Austria
Hi,
I got my Ronin S 2 days ago. I charged the battery to 100% turned that thing on, activated it updated to the latest firmware - so everything was good.
Then I tried to turn off the Battery grip. Didn´t work. I read all the comments on how to do it correct - that thing stayed on.
It turned off by itself overnight.
So next day I wanted to turn the battery on again. No chance! 1 Click - 2 Clicks - waiting - I tried everything - nothing.
Then I tried to charge it. Plugged it in and it charged - lights were blinking. And then i could turn it on.
Whats wrong with the battery grip? I want to turn it on and off whenever I want!!!
https://youtu.be/iwonW7NdIuo
2019-5-12
Hi sebustoned, it seems the way you turned off the grip is not correct, please press once the power button and then quickly keep pressing it for 2-3 seconds to see if it works.
2019-5-13
sebustoned
Austria
hi - nope - does not work.
I also can´t turn it on. When the grip turns itself off overnight I can only turn it on if the grip is charging.
2019-5-13
djiuser_eQnOcqJqkzyU
India
I am facing the same issue. Please let me know if you found a solution!!
2019-7-16
Horn_Bee
Did you ever get this issue resolved? I am having the exact same problem and would like to avoid sending the unit back if it is a simple fix...
2019-9-5
Adi Dobre
Flight distance : 266010 ft
Same here ....
2019-9-6
ShyLama
Having the same issue, does anyone have a solution?
2020-2-18
