A J
Flight distance : 13864580 ft
The max flight range is heavily dependent on the environmental conditions you are flying in. There must be no obstructions between the RC and AC such as walls, tree lines and buildings, the area must be free of interference like electromagnetism and WiFi - if you fly a Spark which uses a WiFi transmission in or near a built up area the signal will be unstable and compromised. Be sure that the antenna is perpendicular to the drone too and is not pointed at it. DJI do advise this in disclaimers in their advertising and the manuals so the max range is not a false claim as many have flown even further than 1.2 miles with the Spark - in the right area. If however you are losing signal at 13 metres then there is something wrong which may be due to the device you are using as much as the drone. And BTW - what will your defence be in court for wanting a 300g drone to be able to fly 1.2 miles away from you and beyond visual line of sight which is a breah of Indian aviation laws for a UAV... Hey Judge, this drone won't let me break the law lol Good luck! |
