DJI Tony
Hi, thanks for the inquiry. You may consider our Mavic 2 Protector Case which is available in our store. The interior of the box is carefully-designed to fit your Mavic 2 with EVA foam inserts that provide an exact fit for your gear while keeping it safe from impact. Ample interior space accommodates the aircraft and remote controller, as well as three spare batteries, power adapter, car charger, battery charging hub, power cable, battery to power bank adapter, ND Filters Set, and a pair of spare propellers. You may refer to the link below. Thank you for your support.
https://store.dji.com/product/mavic-2-protector-case |
