USS Pretty-Bird (NCC-1702)
Flight distance : 872572 ft
Occams Razor Posted at 5-15 10:21
I don’t think it’s the adapter in that I am able to charges multiple devices, camera batteries, razor, etc. with no issues. I’ve also tried a couple of different adapters with both a ground connector and without. The contacts between the battery and charger are clean. Wish I could fly in Algarve like you but I’m limited to a battery with 95% charge so I’ve got choose wisely.
Thank you for your comments.
Another thought...I am assuming that your MP2 charger only charges one battery at a time- e.g. not the 'hub charger'. If this is the case it sounds like the cord with the battery plug on the end has a short. I suggest moving/twisting it in several places to see if you get the current to flow to the battery. if you can find the part of the cord that needs some bend in it for it to work, then you can tape it down in this position until your battery completes it's charge that way. In the end- don't sweat it, Portugal is beautiful and don't let it bother you (fyi I was there for 2 weeks and could only fly for 2 days b/c of high winds ). Just make sure next time you travel to bring several batteries!! I always travel with several bats plus even a backup cellphone (no fun wanting to fly when you've also crushed your phone on a trip ). |
