fans767caf35 Posted at 6-11 02:59
Hi Mindy,
After A few test I think I've found a solution to this. At least for now I don't have this Wiggle movement. I did a quick fast test so I don't have the final conclusions.
Let me try to explain: I use a X-T3. The body itself it's quite small so all the weight it's focused on the "Y" axis. Imagine you pick your phone on a vertical mode and you set your finger under it. If you try to hold without touching it you'll have to force moving your finger a lot to trying to stabilize without falling it. On the other hand if you put your mobile same finger in horitzontal mode it will be easier to hold the phone without falling it. So having this concept, I bought some weight and put the camera on one side of the base plate and counterwieght on the other way and I fixed a lot this movement.
Glad to know the issue has been fixed, it is necessary to use optional counterweights if mounting a longer camera. Please keep us updated if you have further concern. |
