'Not Support Water' Error on DJI Osmo Pocket after Firmware Update
3029 7 2019-5-16
The General
Flight distance : 13609 ft
Cambodia
Not sure if I should call it an 'error,' but when I've been in my menu and trying to switch from 'Slow-Mo' to 'Timelapse' mode it pops up with a message that says 'NOT SUPPORT WATER.'
What's that about? I've just updated the firmware to V01.07.00.20. Could it be that? I was trying to get to 'hyperlapse' but I couldn't get that far. I think to finally be able to get to it, I first had to go to another mode, and then go to timelapse>hyperlapse.
Does this warning/error actually mean anything or is it just a glitch? Has anyone else ever seen this? I also did a search here on the forums and nothing came up, so started this topic. I've never gotten it near water either, so have no idea what would trigger a warning about water, or what 'not support water' would even mean. Thanks for any help and feedback.
Not support water
Not support water
2019-5-16
Oh-no
Hyperlapse is at the Timelapse sub menu.
Not support water, I guess not for waterproof housing use.
2019-5-16
The General
Cambodia
Oh-no Posted at 5-16 23:12
Yes, no issues actually getting to the hyperlapse, it's just when I tap on 'timelapse' from the screen you see in my pic that I get that 'not support water' error flash up and prevent me from selecting timelapse>hyperlapse.
Here's one I made riding around today:
2019-5-16
dronieuk
Flight distance : 17018 ft
I saw the same message too and wondered if it's something that suggests that the mode isn't supported when the waterproof case comes out.
2019-5-16
The General
Cambodia
dronieuk Posted at 5-16 23:55
Well, I'm just glad to hear it's not just me.
2019-5-17
CemAygun
Flight distance : 810 ft
Turkey
I tried multiple times, I could get the error only once, but it disappeared right away...
2019-5-17
fans890f1dc1
It’s possible you have the waterproof case setting enabled. It’s the last item in Settings. Tap it to tell Osmo you don’t have the case fitted.
2019-12-22
Neo Supreme
Flight distance : 76329 ft
fans890f1dc1 Posted at 12-22 04:32
I'm thinking that's what it is too.
2019-12-23
