horizon never straight
902 11 2019-5-18
mickspawn
no matter how many times i calibrate the gimbal, it is never straight on the horizon.  it is WAY OUT.
Ideas?
2019-5-18
A J
Flight distance : 13926112 ft
Are you using ND filters and if so which brand?
2019-5-18
Montfrooij
Flight distance : 2560453 ft
THat was my initial thought also.
ND filters?
2019-5-18
gnirtS
Flight distance : 5712575 ft
As well as the above have you set up the gimbal roll correction (NOT the calibration).  This is a fixed offset you can dial in.
Also, you need to take off from a level surface.
2019-5-18
mickspawn
A J Posted at 5-18 08:34
not using any ND filters.
2019-5-18
Game_of_Drones
Flight distance : 706739 ft
Hi, I had the same issue with my first M2P - No matter how many times I calibrated it or manually adjusted the roll it was at a different angle for each shot.  It also moved horizontally when flying forwards and side-to-side...  I ended up sending it back through DJI for a replacement
2019-5-18
Game_of_Drones
2019-5-18
A J
mickspawn Posted at 5-18 18:14
seems like a defective gimbal to me then - arrange to ship it back
2019-5-19
mickspawn
A J Posted at 5-19 00:33
i never have any luck.  2 P4P went back.. then i got this... crap company
2019-5-19
A J
mickspawn Posted at 5-19 05:21
Wow - 3 with dodgy gimbals - that's not good. Fingers crossed the next one works out well for you
2019-5-19
Francis
Flight distance : 774203 ft
Brazil
Sometimes i have this problem, sometimes . not.
2019-5-19
mickspawn
Francis Posted at 5-19 18:25
what do you do when you have the problem?  are you sending yours back?
2019-5-19
