Refly-ing exact flight paths
5440 9 2019-5-18
parzemis
Flight distance : 256332 ft
Sorry if this is a question that has been asked a ton before but I'm wondering how to save a flight path so that I can fly it exactly the same at a later date as I'd quite like to make a series of photos of the same thing taken a month apart. Any help would be really great, thank you!
2019-5-18
A J
Flight distance : 13838848 ft
What Mavic do you have?
2019-5-18
parzemis
Mavic 2 pro (it's probably a simple answer I'm just new to the 2 pro!)
2019-5-18
DJI Tony
Hi, thanks for the inquiry. You may consider using a waypoints 2.0 feature which will allow you to create a mission path that you could save and be able to pull up again if you would like to fly with the same path. Hope that this information would satisfy your query. Thank you for your support.
2019-5-18
parzemis
DJI Tony Posted at 5-18 11:57
That sounds like just what I'm looking for, thank you, I'll have a look into the waypoints settings!
2019-5-18
DJI Tony
parzemis Posted at 5-18 12:01
You're most welcome. We would recommend being cautious about the environment to prevent the incident. May you please always have a safe flight. Thank you for continued support.
2019-5-20
Dirty Bird
Flight distance : 41442379 ft
You best bet is Litchi.  You can program a mission & repeat it at will with great precision, even with different model aircraft.
The third video shows just how precise it works.
2019-5-20
RichInGa
Flight distance : 449344 ft
My problem with this is that the gimble doesn't stay smooth during a mission.  It moves slightly side to side.  I have a mavic 2 zoom.
2019-5-25
DJI Tony
RichInGa Posted at 5-25 09:53
Hi, we're sorry for the inconvenience. I would like to clarify if you've managed to re-calibrate the gimbal? Did you check the environment, if there was a strong wind during the flight? Please let us know for further check. Thank you for your support.
2019-5-27
RichInGa
DJI Tony Posted at 5-27 12:50
No high wind, and the gimbal works fine when piloting it manually.  So when I fly manually its smooth. When I do waypoints -- it's not.
2019-6-13
