Possible to remap stick assignment?
1266 2 2019-5-18
CineView Media
Flight distance : 5365522 ft
Norway
Is it possible to reassign the stick channels for dual remote use, so that one ieg can adjust tilt with one stick, and pan with the other, or just one of them for both?
2019-5-18
DJI Tony
Hi, thanks for the inquiry. For the dual remote controller, the secondary could able to command the aircraft such as Gimbal dial, Control Sticks, Flight mode switch, and DJI GO 4 app settings. However, the primary will has a priority when commanding the aircraft, therefore, we could use the same command when using the primary and secondary, unless there will be no input from the primary for more than 2 seconds. Please refer to the images below for further details. Thank you for your support.
2019-5-18
CineView Media
Norway
DJI Tony Posted at 5-18 12:56
[view_image]
Hi,
I see you didnt understand my question.
I was referring to remapping of the channels.
2019-5-18
