Smart Controller HDMI Broadcast
2456 7 2019-5-19
DanielVieira
Flight distance : 4633533 ft
Portugal
Hey,
Yesterday had a job that required to do Live transmission throught HDMI via Teradek Bond, but this last bit of hardware was allways losing the feed from SC HDMI out, anyone used this allready?
I had two Teradek's with me and with SC none worked! I've tested with 3 HDMI cables.
Thanks
2019-5-19
CineView Media
Flight distance : 5365522 ft
Norway
What resolution and frame rate did you record/transmit in?
2019-5-19
DJI Stephen
Hello and good day. Thank you for reaching out and for the inquiry. I hope that you can get the best information/ recommendation from our valued DJI Co Pilots who uses the Teradek Bond. Thank you for your support.
2019-5-19
DanielVieira
Portugal
CineView Media Posted at 5-19 03:21
I have tried all resolutions and 50/30 fps.
2019-5-19
aerography.pt
Flight distance : 2012687 ft
Portugal
DanielVieira Posted at 5-19 10:16
I've used many times, and it worked well!
What is the size of HDMI cable?
2019-5-19
DanielVieira
Portugal
aerography.pt Posted at 5-19 11:21
WIth the same hardware (Teradek Bond II)?
HDMI size 1 meter, 3 meters and 5 meters.
I know it works with other hardware...
2019-5-21
aerography.pt
Portugal
DanielVieira Posted at 5-21 00:37
No, used with Blackmagic Design Micro Converter BiDirectional SDI/HDMI, and connected to Blackmagic table.
2019-5-22
DanielVieira
Portugal
aerography.pt Posted at 5-22 02:57
Ah ok...That way i also know that it works!
2019-5-22
