endotherm
Flight distance : 503241 ft
Brunorogi Posted at 5-22 04:33
I'll tell you the truth, when I got the drone in my hands I was missing one of the propellers, but this propeller that escaped was at most 2m away from the fallen drone and got stuck in a tree.
I was also thinking that the propeller escaped in flight, but on second thought, what is the chance of the problem happening 70m high and 20m away from the drop site and the propeller falling almost to the side of the drone?
What I thought was this, in the strong impact with the tree the propeller was arracanda of the drone, simple as well.
It is improbable, but it could quite easily have come off in flight and ended up landing close to the main wreckage. The design of the P3 series props is that, as long as the motor is spinning, it tends to thread itself ON to the prop hub. The prop motor won't run backwards, so it shouldn't be able to unthread itself. However if it wasn't on tight, the normal acceleration could be enough to turn the prop in the correct direction, but not aggressively enough that it "self-tightens" itself into the hub. Therefore, normal flight can be achieved, but it is a delicate balance. If you slow suddenly or abruptly return the sticks to centre, the momentum of the prop is enough to keep it in rotation. The motor is slowed or stopped in relation to this momentum. That can be enough to have a counter rotational effect on the prop and it unscrews itself. Now you have two separate objects tumbling in the air, without propulsion. They will continue on a trajectory consistent with their previous momentum and fall to earth at the same speed. Assuming they weren't acted upon by a lateral wind, the lighter prop could conceivably end up very close to the heavier body. Even when the space shuttle broke up on re-entry, bits that came off the main craft at the same time ended up very close to each other on the ground. It has more to do with momentum than weight. Had it been intact when it hit the trees, you would then have to come up with a reason for the props, which are spinning "forward" to spin backwards in relation to the motors which are also spinning "forwards". Obstructing the leading edge (hitting a branch or the ground etc.) will serve to drive the prop on tighter. Obstructing the trailing edge will have no effect as the rotation will quickly move away from the obstruction and strike the leading edge instead. The only way a prop should come off on the ground is if it breaks or the hub is stripped. It is unlikely to just come off if it impacts a tree/branch or the ground, it is more likely to snap the prop blade. Are they genuine DJI props, and for the correct model? (P3 props have a white plastic centre, not a metal hub). Is the thread cut into this hub stripped out at all?
If you look at the flight data, all the speed error messages were after 6min 12 sec. Anything after that time is when you were crashing and the aircraft was tumbling out of the sky. You can see the X, Y, and Z axes are changing quickly and wildly. This is typical of a tumble, I have reviewed many crash data and this is very normal. It suddenly rotates forward nose over tail, while rolling side over side and spinning to face every compass heading.
This is an example of another crash investigation, see the directions and angles change as it falls from the sky?
This will happen every time you only have 3 props spinning -- it is not enough for flight, but enough to flip direction. Any angle beyond about 30° pitch or roll is the aircraft crashing, it is out of control. With 4 intact props it would have a chance of recovering level flight all by itself, especially at your height of 70m or more. If you notice the speed errors, they all occur as the aircraft is crashing and tumbling with the pitch/roll values changing wildly at that time. Those values are physically possible. The compass and gyroscope are working properly. It is showing that your aircraft is on its side or upside down at the instant that the data is sent. The telemetry will continue sending these sideways and inverted artificial horizon values for all the time until it hits the ground and the signal is obstructed or the electronics are damaged and it is incapable of transmission. The speed error message isn't particularly verbose to tell us what was going on, but I'd suggest one of the motors was spinning overspeed with no resistance. The aircraft was trying to regain control and probably spinning a motor at 100% (depending on its angle). However if the prop was missing, it is possible that the motor is spinning faster than that, and the system reported an overspeed error. Depending on the firmware a different error could be returned. Sometimes you get a missing or obstructed prop or a loose prop warning. It might not have had enough time to make a determination that a prop was missing and that is the best it could determine considering all the rapid X-Y-Z axis changes. The last data entry of the record is when it hit the ground (the battery possibly popped out?) or the aircraft was so low that you lost line-of-sight between the aircraft transmitter and the remote control receiver, and the data stream cut out.
The DAT file is a LARGE file recorded inside the aircraft's flight recorder. It records ALL the sensors and performance and movement commands. Hundreds of them, dozens of times per second. It will keep recording even when stationary on the ground until the power is interrupted. I haven't had to retrieve one for a while, but if I remember correctly, you set the aircraft to Enter Flight Data Mode in Advanced Settings through the Go app, then connect the aircraft to your computer like an external USB hard disk. The internal storage will show up and you will need to search for that file and copy it off. You need to plug into the micro USB port on the body of the aircraft beneath the nameplate, not the camera/gimbal USB port. The data transmitted and recorded for your flight is much smaller in size but it does contain 99% of what we would need to analyse the flight in a spreadsheet or dedicated analysis software. The PhantomHelp web page is good visually, but does not show you all the parameters. It is much better than it used to be and now shows horizon and stick movements for that instant, for example. I am hoping that there is definitive evidence that a particular motor lost a prop or stopped completely in flight. It will show a sudden loss of air resistance and thrust, motor speeds, current draw, and if it was overheating etc.
At the moment it is looking highly likely that there was a birdstrike and you lost a prop, but I'd be more confident after viewing the DAT. |
