Osmo Action Bug Custom Mode Dewarp
2490 7 2019-5-26
ShawUK
Hi,
I've noticed I can not save 4k 60p rocksteady with dewarp. Dewarp does not save to the custom mode, although it does work manually turning it on every time.
Please fix in the next firmware update :-)
2019-5-26
djiuserCCO
Flight distance : 178688 ft
Is it only in 4k60 you cannot save DEWARP. I save my C1 setting at 4K30 with Dwarp. All functions are present whenever i recall my C1 setting.....including Dewarp.
I'll check to see if i can save Dewarp in 4k60.
2019-5-26
djiuserCCO
The same thing happened to me. Just tried saving a setting with 4k60 with Dewarp. Whenever i went back to that setting.....Dewarp was no longer on. Tried to set a few times with no success.
Hopefully DJI will fix this in future firmware updates!
2019-5-26
DJI Stephen
Hello and good day ShawUK. Thank you for reaching out and for the inquiry. With regards to this matter our engineers are aware of this case, and will optimize it as soon as possible. Thank you for bringing this to our attention and thank you for your support.
2019-5-26
fans49c1baf6
Flight distance : 2015627 ft
DJI Stephen Posted at 5-26 09:34
Thank you very much for responding to the Dewarp not being saved in 4K 60 P, the main reason to buy  this camera over the competition is for this feature. I am relieved that your engineers are working on retention of this setting after powering down the camera and then powering it on again or as retainable in a custom mode.
2019-5-26
DJI Stephen
fans49c1baf6 Posted at 5-26 13:01
You are very much welcome. If you have any other inquiries or concerns with DJI. Please feel free to post it here at DJI Forum. We are here to help and support you.
2019-5-26
fans8cefe4ae
Singapore
Same for 4K50. Fix it asap guys.
2019-6-4
David Monostori
I noticed this too, but the dewarp is saved, but not loaded properly. If you cycle your custom settings with the video button and do switch to a timelapse or slowmo and back to video the dewarp is on. If you switch between video with different settings dewarp is off.For example I have 4K60 4k30 4K30HDR SLOWMO4X and timelapse. Switching between the first 3 the dewarp is off on 4K60, but if i switch to slowmo or time lapse and back to 4k60 dewarp is on! Definitely a bug, but there are workarounds. Hopefully will be fixed very soon. RockSteady also seems to be off in preview and turns on when I press record sometimes.
2019-6-8
