Jakab Gipsz
Hungary
S-e-ven Posted at 6-2 17:20
I dont think that vibrations can loosen a batt. Unless it is not totally or rightful attached, of course.
My theory is size-expansion b/c of high currents in sport or heavy wind conditions, perhaps.
At least, since I had some "pregnant" batteries and trouble to slide them in or out easily, I am pretty sure that is more a battery housing size problem. Which the longer latches can cover up just one more millimeter
You may be right, but don't underestimate the power of vibration. These vibrations are always present, which is why it is mounted on the gimbal rubber buckets. The vibration can move up and down from a 0,001 millimeters to a 0,011 millimeters, slowly moving, scratching the fixing claws.
The problem is not the length of the claws, but the fact that the fixing surface of the claws is not tilted but straight and does not close tightly. |
