Ok guys, it's time to create this big post. First of all - sorry for my english, i'm from Ukraine and only learning englitsh at this time. Dont gudge me hard)))
So, i'm using DJI products rof long long time, since first DJI F450 frame and DJI NAZA flight controller.
First my image stabiliser was DJI Zenmuse H3-2D for my GoPro action cam.
After H3-2D i buy H3-3D and after H3-4D.
Than after long time of usage it has become the DJI Phantom series and i use this gimbals until Phantom 3 become...
After this i have buy DJI Inspire with Zenmuse X5 camera and little time after DJI release adapter for Osmo to X5 camera.
I know very well how DJI stabilization works and all i can say --- DJI stabilization was perfect, perfect UNTIL I BUY DJI RONIN-S
DJI, i don't cnow what you think but all this ussue's with shaking problem, jerky footages and other issue's - this is a dislike and manifestation of total disrespect for your customers!
DJI RONIN-S is totaly unusable gimbal for camera without IBIS (in body image stabilization)
I have use my RONIN-S for half year with Sony A7sII and i have also see some jelly effect. Now i'm using it with FUJIFILM XT3, it has no IBIS and this is nightmare.
All my footage need software post stabilization! ALL!!!!!
Yes, i'm PERFECTLY balance my gimbal
Yes, i have try many many many settings variation
Yes, i use Auto calibration, system calibration and other auto calibration
Yes, i have try factory reset, a try new firmware, i try downgrade firmware but all this not halp!
Yes, i try many variation's for stifness seting and other adwanced setting!And YESS, i walk like ninja PRO everytime
I also try use external GPS module for Ronin-s and nothing change
Here some fuutage's from my Fuji XT3 with DJI Ronin-S. I made with different focal length and all time have rebalance my ronin after focal distance change. I have ewerythink done perfectly but here is the result
looking forward to reply. I have the same issue. I just went from a Pilotfly Adventurer with a Sony a6300 to Ronin s with Sony A7S ii. I am not happy with the results. panning has noticlalby more jitter as well as the general instability your clip exemplify
i have had the same issue as well. I just followed the steps to rebalance the RoninS with one of the legs up on the battery charger. When i went to run a balance test it said the Ronin S was not balanced correctly. I was always thinking it was balanced perfectly when the camera was perfectly aligned with everything. So i will report back after i go outside and take a few runs with the Ronin.
HRPOWWAA Posted at 6-16 06:59
Read the manual properly. You should NEVER balance the Ronin with one leg up!! Always keep it straight! Otherwise, you can never balance your Ronin correctly.
Only when performing the balance test, you should but something under one leg.
I have the Ronin S. But even when my rig is fully balanced, test on the Ronin app results excellent on all axes, I still see some major shakiness and not sure why. I often find myself stabilizing a lot in post, when the ronin should be doing this job for me.
Can anyone help me understand why it is not smooth.
Nobody will help us because all this issues and problems from factory defect and DJI will newer told this.
I have the DJI Ronin SC and exact the same problems!
80% of my footage must be corrected in post...
All axes are balanced excellent (so says the balance test)...
I using only a sony alpha 7iii with stock lens 24-70mm OSS and the weight of the kamera plus lens is very low. But my ronin sc still have the same problem.
I had similar issues with my Ronin S. I had the feeling, that one motor sometimes suspends for a really short time. I'm using the BMPCC4K-Camera, it has a different formfactor, why I had these issues I think.
My solution was:
1. balancing all axis to "excellent"
2. System calibration in the App with camera on it
I think, I fixed it with that. Maybe you can give it a try?
Edit: Nevermind, you already did the calibration....
I had the same problem with my ronin S and nobody from DJI did not want to reply to me here on this forum. My shop send it for repair. They changed the motors and now it works much better. DJI support is awful if you buy anything online.
Hi guys. I've just bought a Ronin S last week an the first footage was unusable. All I did before shooting was balancing the 3 axis to "excellent" and an autotune. The footage was exactly as jerky as what we see on that thread.
I observed that the motors were uncorrectly set by the autotune. The autotune is applying a much too low stifness to the motors. You have to adjust stiffness manually. It's easy. You can consider that a motor has the right power amount when you begin to hear a slight hiss in it. So raise up each stiffness axis to the limit of hiss/vibration. If it's vibrate, the stiffness is too high, if it doesn't do any sound, it's too low. Once you have done that, try it in free mode, without smoothtrack and use it in all positions to check vibrations. If a motor vibrates, lower the stiffness by increments of 5. Check if the motors are heating or not. If the motors are heating, check the balance. Now you can adjust smoothtrack at you taste. My Ronin S is now perfectly working.
Wango92 Posted at 9-15 00:30
Tima_007 Posted at 7-31 23:45
ok dji, any firmware update to fix major issues?
Or you fix issues with new Ronin SC and forgot us with old Ronin S ??????
I have extacly the same problem! I have too an X-T3 but with OIS on the problems go away. The moment I turn it of, it's exactly like your videos. Does this mean Ronin S just works with stabilized lens and or IBIS ?
This is so bad, If I buy a lens, for example the Fuji 35mm 1.4, and put it on the Ronin it will be shaky as hell.
Please, get back to me if this problem persist or if you found the solution
Hi thank you for your post.I have the exact same problem with my DJI Ronin SC.and Fuji XT3 with 23mm prime lens. Very light setup. Gimbal balanced. Doing ninja walk.have tried re calibrating. Nothing works.My footage looks the same as yours. Is hev been using gimbals for over 5 years and never had this problem, even with the Crane 1.
Did you ever find a solution? I have done two professional shoots now with it and both times footage is unusable and no response from DJI. Please help.
Guys I use it with 5d mk4 without ibis and stabilized optics and it has never made this defect to me. So I guarantee you that it is not a defect factory but a defect of yours or surely something wrong. Another thing you can try is to ballast the room (make it heavier) because if the room is too light the ronin s does not work very well .... for this they did the ronin sc.
I don't believe it is my fault. I have used many gimbals for many years and have created incredible footage with them. Here is even a stationary shot from my ronin sc, balanced excellent and auto tuned and these are the results I'm getting.
safinest3 Posted at 12-4 04:35
Yes autotuned. Tried every different variation of the settings in the app, spoken to other ronin sc owners, tried contacting DJI....and nothing. I am using this as a tool for work and have shot many many things with gimbals. I have previously been a Zhiyun Crane 1 user and achieved these kind of results. www.drewcox.co.uk
I have never experienced this on a gimbal before. I want to know if this is for all Ronin SC users or if I have a bad device and need to get a replacement. Please can you respond DJI, this is happening to a lot of people and I will be making a full video review to discuss this as it is unacceptable for a device that sole purpose is to stabilise the image. All this is doing is making it more shaky. And i had to pay £300 for it. My handheld shots are smoother than this gimbal. Please DJI I have jobs coming up and I need to use your product.
I had the same problem as the OP, Sent my ronin to reparation, and came back with the same problem. They found some problem and they said they "fixed" it, but no luck. It's just a shame this product
The footage is better handheld.
DJI Ronin Products are not reliable at all. There are so much inconsistency.The be honest, I'm trying to sell it. Time to move on and change to another reliable brand. I can't get professional stabilized videos with this
safinest3 Posted at 12-4 08:40
I don't know what to suggest buddy other than send it back, it's not right, that's for sure. DJI needs to address this as a matter of urgency. Let me know how you get on.
Tima_007 Posted at 6-18 22:29
How do you know this?
I'm having a lot of problems with it - make adjustments seems OK, go out in field and come back with unusable footage - rinse repeat for 6 weeks now. Rebalanced, system calibrated, auto tuned etc.
A have Ronin S now more than one year. For all this time i trying to make it work properly but nothing is help. I have read a tone of forums, seen a lot of video, make ajustments, and nothing halp.
Now my Ronin S has manual settings, it work a little batter but again, without IBIS footage is unusable.
P.S. Stop doing this (try auto calibration, try ninja walk, try system calibration and etc)
Tima_007 Posted at 12-29 01:20
1 year and you're still at it - crikey :-)
Footage was a little better today after upping pan stiffness to 54. But this has introduced like tiny vibrations/jitters that I noticed on a walking shot. Seems to coincide with my steps. Don't know if it's my technique or not.
Did someone find a solution for Ronin SC ...ty jitters, and shaky footage? I've recently bought mine and it's crap. If I could I would return it but the shop where I've bought it can't accept it because "it is activated", that means I turned it one once. I shoot on a Fuji XT-3 and XF 35mm f1.4 , so no OIS or IBIS
Giovi86 Posted at 5-10 08:53
There is no solution. You can tweak some stiffness settings but the is no one solution to fix Ronin S and make it usable.
Ronin S is not perfect stabilizer, done.
I sell my one and bought Zhiyun but it's also not perfect ))
ugggggghhhhh - I'm seriously bummed to read this forum. I have shaky footage, a gimbal that if lifted sometimes the battery and tripod stand will whirl around like a propeller plus the plate slips off when underslung (I have a heavy rig - 5d mark iv with 24-70 - but within weight limits. I just did three shoots pretty much back to back with it. this was a new one after having to return a Ronin S because of a battery problem. It worked pretty well for the first shoot, I charged the battery, battery charged fine, but now - crappy footage - and whirly bird issues - Also, the Gimbal button doesn't work well when engage to freeze the camera - it still pans...............
I've done all the calibrations, etc.... balance, auto tune -
hmmmmmm - could this be battery related?
Hello, I have got all the same problems with shaky footage even with my Ronin M! Any solution yet? Is this normal?
I believed that 1200USD device should work well and provide professional results. :/
I’m not having these issues, but I am using a lighter camera, the Sony A7III. Is everyone certain they are balanced? If you are balanced you should be able to sit your Ronin-S down, double click to center it, and then turn it off. When it turns off the camera should not move at all. You should not be able to tell by looking at the camera when the Ronin-S actually turned off.
method007 Posted at 8-21 22:30
Well balanced, very light setup (GH5S + 25mm f1.7). I even tried to adjust the stiffness after auto-tune stability. Seems it helped a bit but didnot resolve the issue completely. (Besides - I have seen loads of supersmooth footage out of the box ronins - no sw tuning just properly balanced. And I cant get anywhere close to that)
PhilippN Posted at 8-24 01:25
Tima_007 Posted at 5-11 03:21
It seems like the way you are balancing is wrong. Film how the balance is setup w/ the motors off on all axis.
If Zhiyun isn't great either then something must be wrong at the setup level.
safinest3 Posted at 2019-12-4 04:35
The lens is so small that its not even possible. And it is supertight with the camera (since it is panasonic original). There is no way it could be related with my shakiness.
