BobWinNV
Flight distance : 284209 ft
My testing has found the audio on the Osmo Pocket both using the internal microphone and with using the audio adapter to be much better after updating to FW v01.07.00..20
I have found that the audio adapter does not recognize a microphone that is only sending audio to either the tip or ring. It wants audio on both the tip and ring now. Also if the audio level into the audio adapter is lower than a certain level the microphone will not be recognized. For instance, before the update the R0DE Wireless GO internal microphone would work with the audio adapter when the R0DE Wireless GO's level was set to Low but after the update the Wireless GO's internal microphone needed to be on the high setting before the Osmo Pocket showed that the microphone was recognized. Other hotter microphones plugged into the Wireless GO will still work in the Wireless GO low setting though.
Bob |
