Magic Maniac
Flight distance : 11549 ft
I have only been flying for a week but I am wondering if I got a bad controller or drone. I have been getting intermittant problems that don't make much sense.
Example 1. Return to Home - normally when I press return to home the drone flys to the spot and lands. Sometimes, however the drone flys over starts landing and then hovers 5 ft above the ground. it doesn't land it just sits there. This has happened 3 times all the other times it worked normally.
Example 2. Active Track - Yes it's a little glitchy (loses focus a lot) but twice now it has stopped tracking and just hovers. When I manually try to move it. it ignores my commands (I was about 200ft away) so I tried to exit Active Track mode. I tried hitting the red X, itried jumping in and out of the menu. I tried hitting the "normal" menu selection. Nothing worked! The only thing that worked was hitting retuirn to Home, landing it and then rebooting the controller and drone! Then everything worked fine.
Example 3. Similar thing happened when i was in Point of interest mode. The drone stopped responding to commands and I had to land and reboot to get it back to normal.
I was flying all last week in desert outside of Las Vegas. no trees or obstacles over 5ft tall. All the problems seem intermittant
So, Should I return the drone and get a different one?
