ff22
I did the firmware update via the app or however it did it. But I had not put an sd-card in the camera. During the process it told me I needed to put a card in. I did and the update continued and finished. Afterward, I noticed the xxxx.bin file was on the card. So which ever way you do the update, the xxx.bin file is copied or uploaded to the card and than executed and installed. I just went looking and that file is no longer on the sd-card. So it must get erased at some point. But I found the log file for the update and it has the following line
[E:\OSMO_ACTION_FW_V99.99.99.99.bin] detected, card sn [0x9b180f98].
So, I presume that the bin file is located in the root or top folder or directory.
Good luck |
