Infrared sensors when RTH activated.
2121 5 2019-5-30
tomlewis
Flight distance : 37995 ft
Hi everyone,I just wondered if anyone knew if when the RTH is activated on Spark if the downwar facing infrared sensor disables or if there is any way to disable it as when flying in slight mist it seems to think it is close to the floor all the time?
Anyone got any ideas.
Thanks
2019-5-30
msinger
Flight distance : 228255 ft
The downward sensors cannot be disabled in DJI GO. If you buy Litchi (available in the app store on your mobile device), you can disable the downward sensors and then switch back to DJI GO. At that point, the downward sensors will remain disabled until you either re-enable them in Litchi or install new firmware on the Spark.
2019-5-30
tomlewis
msinger Posted at 5-30 07:11
Many Thanks for that i will check it out!
2019-5-30
tomlewis
I have had a look but that seems to be for the Mavic and Phantom. Do you know anything else or free apps that do something similar?
2019-5-30
msinger
tomlewis Posted at 5-30 09:09
It works for the Spark too. I own Litchi and have used it to turn off Landing Protection on my Spark.
2019-5-31
tomlewis
msinger Posted at 5-31 06:18
It is quite an expensive application though $25 +
2019-6-1
