Jakab Gipsz
Hungary
TimothyD Posted at 6-4 06:46
Yup.... I agree it should be "that simple" However again, as I've mentioned prior in this post. I have the drone in the air, I see and click on the remote icon, I see and click on the tripod icon...nothing happens. It does not go into tripod mode. It stays at Normal mode...
We tried to help you, which takes so long because you have to pull all the information out of it with you.
If you describe the following, we'd be over:
- xxx version I use DJIGO4
- reinstalled xxx times
- xxx firmware on Spark
- I use xxx android phone
- The Spark is in the air
- I choose the signal and nothing happens
I write this down so that everybody understands that it can only help in knowing the exact circumstances, otherwise there will be a lot of unnecessary guesswork. |
