nickedw
Flight distance : 2177287 ft
OK turns out this is almost certainly a simple sd card error, after more tetsing today. DJI when you hit a card write error why would you want to continue the mission? nobody is doing this for fun, so at least make it super-obvious, or better still, pause the mission. It turns out this is very easy to not see and everything carries on if you didn' see the one message when the first image write fails.
I was using a (fairly expensive) 128GB card and it died a bit harder on me today, so I noticed the error because I was watching the image counter like a hawk, if I wasn't, I would probably have missed this.
As an aside my new invertor in my truck, 3-way parallel charger and 5 batteries means I can pretty much fly indefinately - which let me chew through around 14 battery cycles today, well over 6 hours in the air in one day - is this a record!?
Regards,
Nick
