No USB-C transfer for Osmo Action?
9601 4 2019-6-2
davesantos
Transferring the microSD card is clearly the unpleasant process for many.
Connecting the camera into my computer seems to only charge the Osmo Action.
No other connectivity to be found. Not certain if its my setup. Not sure if firmware can fix this, but I suppose this is the consequence of early adoption.
2019-6-2
DJI Stephen
Hello and good day davesantos. Thank you for reaching out and we appreciate your interest in our products. I have forwarded this thread/inquiry to our related DJI team for clarification. I will give you the feedback as soon as possible. We appreciate your patience and continued support.
2019-6-2
ff22
Turn on the Action and plug it in.  The screen should show a prompt "Connect (or cancel?).  Tap the connect and it should show up as a drive on your computer.  It does on my Win7 machine.  I can then copy/move/delete files back and forth.
2019-6-2
davesantos
ff22 Posted at 6-2 13:46
Ok the order in which I plug-in and power on seems to matter, otherwise it behaves like I'm plugged into an external power source. Thanks
2019-6-2
Dunlop
New Zealand
Thank you that worked perfectly on my iMac.
2019-6-2
