Does shooting RAW have more pixel quality over JPG?
AntDX316
Flight distance : 3394731 ft
If everything w/ the colors are matched identically and everything else looks-wise, is the image detail quality higher with RAW than JPG?  Does RAW contain more "metadata" than JPG and that is the only reason?  Like you can bring up the underexposed that would have been lost in JPG and you can correct the overexposed a bit more than JPG in Post?
2019-6-2
Mark The Droner
Flight distance : 2917 ft
Are you aware that JPEG, by definition, is a lossy format?
2019-6-2
AntDX316
Mark The Droner Posted at 6-2 16:35
So JPEG has worse details?  No wonder my PNC shot wasn't too good.  I forgot to take it off JPG and put RAW after using Dronedeploy!
2019-6-2
Bashy
Flight distance : 2354357 ft
RAW will use up a lot more space and take longer to process, try doing a 360 pano in jpg, then try again in raw.  But, at least with raw there is a lot more data to play with when it comes to editing, always worth shooting in raw and jpg, if the jpg is good enough for what you want then it can save some editing time, more so if you have many images....
2019-6-2
AntDX316
Bashy Posted at 6-2 18:33
RAW in the Sony A7 uses way more storage than JPG.
2019-6-2
*DM*
Flight distance : 507087 ft
Yes. But RAW will look similar to unprocessed D-Log ... flat until post processed.
These days, processors have advanced and many good cameras shoot impressive Jpeg's.
I would argue that for most Jpeg is the way to go if using a high quality cam. File sizes are considerably smaller too and you can of course adjust pre shot parameters/settings in Jpeg.
Then there is the issue of RAW converter and editing programme quality. They are not all created equally.
Add the time and skill needed. There is just as much potential, more probably, to mess things up in raw.
Unless you know what you're doing or shoot client material I'd personally stick to Jpeg unless the camera processing is really bad.
2019-6-2
AntDX316
*DM* Posted at 6-2 23:15
I mean, you can shoot in RAW with DroneDeploy but the settings are not automatic so you risk having the shots messed up somehow and not look good.  Then you would have to post-process 200+ images yourself.  Blurred images, overexposed, underexposed become a thing when not in automatic JPG mode.
Look at this.
https://drive.google.com/open?id ... nb_vTG9t7DCwRpMiWRo
2019-6-2
Bashy
In lightroom and other software, you can add a preset that can be added to multiple images.
2019-6-3
AntDX316
Bashy Posted at 6-3 18:06
of course, just copy and paste the settings
2019-6-3
