Qs on Ronin-S & stick?
722 4 2019-6-2
HedgeTrimmer
Q1: Anyone using Ronin-S with Monopod stick?
Q2: Anyone found shock-absorbing Monopod stick to use with Ronin-S?
2019-6-2
DJI Tony
Hi, thanks for the inquiry. We're hoping that you could get the best recommendation that you may need from our valued DJI Forum members who use the Ronin -S. Thank you for your support.
2019-6-9
jiD One above all
Flight distance : 137388 ft
Denmark
q1
using the Manfrotto 561BHDV-1 with my Ronin-s
2019-6-10
HedgeTrimmer
jiD One above all Posted at 6-10 03:27
q1
Thanks.  Been looking for a Monpod that has some built-in vertical shock absorption.  Used to make a Hiking stick that had a removable cap which covered screw threads for camera mounting.  Hiking stick had built-in shock absorber.  Believe shock absorber was fluid piston with spring.
2019-6-10
jiD One above all
Denmark
HedgeTrimmer Posted at 6-10 19:56
ok sounds cool.  unfortunately I cannot help with that
good luck
2019-6-11
