KEJ
AntDX316 Posted at 6-6 00:13
I assume the effects are probably better with Affinity but I already have Lightroom. Is the image effects way better though?
What takes 30 minutes?
Hi
Have you taken your AEB pictures in sets of 5 ?
If so, try and keep your drone still whilst you take the pictures,(from the files you uploaded) take 337, 338, 339, 340 & 341, you can see the drone or camera must have moved, could cause a blur etc if it happened as the shutter was open.
Also I usually take jpegs and raw at the same time, then pick what you want to use.
347 - 351 appear to be more fixed, so quickly using 5 of your raw files, this took 11mins, so these are really HDR(AEB), just keep up the good work.(Could have straightened and got rid of the vignetting etc.......).
