DJI4Survey
Flight distance : 6484478 ft
Alright, SDK remote does connect to the P4RTK fine. The issue is there are very few apps that support it.
DJI GO 4 does not recognise the aircraft. GS Pro definitely does. If you are using GS Pro and a Network or CORS correction you should be able to use it easily.
It does seem to be able to use the DRTK2 correction as well, however, there is no option to set the base coordinates using GS Pro.
So you would have to take note of the base coordinates at setup and translate all the data based on your actual base coordinates after the survey was completed. Not a deal breaker, but a pain in the arse.
DJI, if you read this, add the ability to enter base coordinates to GS Pro and I will be very happy.
I think the SDK controller will work fine with 3rd party apps as well, once they are developed to handle the hardware.
Cheers, |
