same issue with usb c cable stuck
1844 6 2019-6-6
ZhoItuaNeau
Chile
Hello! So I unboxed my new ronin-s and I started to charge it, but when I tried to unplugged it, it got stuck! It won´t come out now. I´ve seen in other thread in this forum the same problem but no solution from DJI other that taking it to a phone service, Please is there any real solution? I'm not able to ship it over the US.
greetings from Chile.
2019-6-6
DJI Tony
Hi, we're sorry for the inconvenience that it caused. We would recommend removing the cable from the charging port of the Ronin -S with extra strength to see if you could remove it. However, it's recommended to make a video while doing this so that if ever that there will be a problem with a Ronin-S this would be documented. Please keep us posted on the latest progress. Thank you for your support.
2019-6-6
ZhoItuaNeau
Chile
thanks for your response! so, if I do it, is there any chance I could mess up the internal machinery of the ronin s by removing the cable with extra strength?
I'm also guessing that the usb-c has an inside estructure with some kind of "teeth" that holds on to the port, so I'm afraid that if I pull out too hard those "teeth" would break?
2019-6-7
djiuser_ps6EPyWIVgSW
Ecuador
HELP PLESE!!! How can i fix this horrible problem ?? If someone know the solución please let me know, i'm very sad ! It is not easy to get a ronin S, i had to work a lot because i really wanted to get a great equipment of photography.
2019-8-18
Giagabriela
Ecuador
Hola! Pudiste resolver el problema? Me pasa lo mismo... No puedo más
2019-8-26
Giagabriela
Ecuador
DJI Tony Posted at 6-6 10:22
Please tell us the solution. It's horrible to get this kind of problems with DJI...
2019-8-26
DJI Tony
Giagabriela Posted at 8-26 17:22
Hi, we're sorry for the inconvenience. If the battery is stuck and unremovable even you put with extra strength, we would recommend contacting our support using the link below for a further evaluation of the Ronin-S that has stuck battery. You may reach our support using the link below. Thank you!
www.dji.com/support
2019-8-27
