DJI Assistant 2 Mavic Software, Download, Guide, Mods And More
6076 5 2019-6-6
Filmsr
Philippines
The DJI Assistant 2 software contains extra settings and utilities for all DJI equipment such as drones, gimbals and cameras.
With the DJI Assistant 2 Mavic, you have options to upload  flight data, black box information, calibrate your vision sensors and upgrade your firmware.
There is also a DJI Assistant 2 Simulator for testing flight parameters and practice flying your Mavic Pro.
The DJI Assistant 2 download and install only takes a few minutes and is available for Windows and Mac computers.
This post contains all the essential information and more on the DJI Assistant 2 app for the Mavic quadcopter. Now, if you have a Phantom 4 or DJI Spark, the DJI Assistant 2 is the same version. Therefore the below Assistant 2 settings and utilities will be very similar.
Now, the DJI Assistant software is for all DJI equipment.  Their equipment all have a micro USB port. Then, with the DJI Assistant software installed on your computer, you connect your DJI device to your computer.
The DJI Assistant software will recognize the device whether it is the latest Mavic 2 or a DJI Goggle, Mavic Pro, Spark, Phantom, M600, Osmo, Zenmuse or Lightbridge flight  controllers etc.
For most DJI equipment, the DJI Assistant will only allow you to update the firmware.  It is different for their quadcopters.
Now, with older versions of the DJI Assistant 2, it was very easy to modify your Mavic Pro quadcopter to make changes to flight parameters and other features.  We will look at these extra settings and how you can still modify your Mavic Pro using DJI Assistant software.
About The DJI Assistant 2 Mavic
The latest version of the DJI Assistant 2 Mavic software contains the below components which we will look at in turn.
  • Firmware Update
  • Data Upload
  • Black Box
  • Calibration
  • Simulator
  • WiFi Settings
  • Restore Factory Defaults
  • DJI Privacy Policy and Terms of Use of the DJI Assistant 2 app
The DJI Assistant 2 software is not a cellphone app. It is installed on computers and there are Windows and Mac versions. The DJI Assistant software is almost totally different than the DJI Go 4 app.  The only similarities is that you can update the firmware using the DJI Assistant or the DJI Go 4 app.
2019-6-6
Penster
Flight distance : 1056 ft
where is the download link for windows or android chromebooks?
2019-6-16
DJI Tony
Penster Posted at 6-16 05:59
Hi, thanks for the inquiry. The DJI Assistant 2 can be downloaded to your Mac/Windows by visiting the main page of the Mavic 2 Pro or clicking this link: https://www.dji.com/mavic-2/info#downloads. You may also refer to the image below for you to determine the DJI Assistant 2 for Windows which is in the blue box and for Mac is in the black box. Thank you for your support.
2019-6-16
Penster
thanks so much
2019-6-16
BudClem
Are there any known problems at this time, regarding connecting the RC to DJI Assistant 2 Mavic v2.0.8 in order to do firmware update?
2019-6-17
DJI Tony
You're most welcome! Should you have further concerns, please let us know.
2019-6-17
