AntDX316
Flight distance : 3394731 ft
If you change the RTH alt does the battery home indicator change such as if you increase it from 60m to 200m or 500m, does the timer of how long it needs before it has to come back w/ no battery change? I know the home indicator may be based upon the current load because when I drop from high-alt the bar is changing rapidly and the home time indicator starts to drop fast. Of course, I would never RTH to 500M but if you mess up w/ low battery by losing connection, your drone will run out of juice and crash?
