fans7892b049
Flight distance : 209518 ft
Q: Are you able to switch between Photo and Video? IF NOT...then you may have the same problem I did (and just solved thanks to an earlier post from last year). Try taking out the SD card and see if the problem persists. IF the problem goes away...then you need to reformat the SD card. Note: I had to reformat mine via my computer before the DJI Go app would recognize the card to even be able to reformat it using the app. |
