Mark The Droner
Flight distance : 2917 ft
Sounds like BS to me. Who wants to sit waiting for fifteen minutes? That's just stupid.
I wouldn't call the less than perfectly accurate satellite fix an error. I would say it's either within specs or not within specs. But even if it's not within specs, that doesn't mean there is an error in the system. The system can only do what it's capable of doing relative to the visible satellites at a given location.
It's true that waiting a bit will potentially improve accuracy of the "fix" relative to the surface of the earth. That's because waiting a bit allows the GPS/Glonass module to acquire more satellites for more accuracy. IMO, 30 secs is usually plenty of time. Sometimes you might want to wait for up to a minute or so. If the accuracy is off by a few feet, so what? Also, once you launch and the elevation mask decreases, satellite fix accuracy will improve dramatically, even if your home point is a bit off.
Also, just my own rant, I hate the acronym GPS these days. It's like Kleenex. Not everybody uses Kleenex only, and not everybody uses GPS only. I like "satellite fix" better. MHO
Good luck |
