Aardvark
Flight distance : 384432 ft
Edit 6:- 24th July:- After waiting two days for the Osmo Action to mature a bit, I decided to jump in again after identifying a device locally available that has been manufacture in June 2019, the first two were both April 2019. Hopefully I will have more success with the firmware on this model which I plan to manually download and install via micro SD card (if the activation process allows). This unit also has extra hole(s) in side as described in this other Thread.
Edit 5:- 22nd July:- After much deliberation I've obtained a refund on this faulty unit, the previous 'work around' to update to V01.03 seems to have been just that, other than a permanent fix. Which leads me to believe that as the unit failed again just after latest update (V01.04) that there is in fact some kind of hardware problem with a certain batch of cameras (this was my second unit, after first had failed in exactly the same manor).
Edit 4:- 21st July:- After upgrading my Osmo Action to V01.04.00.10 when it was released (17th July), my camera now seems to have reverted back to the functionality of the V01.03.00.10 build. First noticed today (21st July, four days after update).
For example I no longer see the 'RS' icon on front screen, I no longer see 'underwater white balance', and so on.
I have edited thread title to reflect what I believe to be the problem from my perspective.
Edit 3:- 13th July:- After transferring my log file to DJI they provided me with a sollution to the problem, my camera is presently at V01.03.00.10(6460) with Rocksteady and 2&5 second delay for photos now working. I will post again should the problem reoccur :-)
Edit 2:- 5th July:- After a few days use the problem mentioned previously returned, please see Post 33 onwards for ongoing progress.
Edit 1:- 30th June:- After much consideration I decided to buy another DJI Action, this time I've had no problems at all after updating the firmware on 28th.
One of the draws for me was the HDR video, BUT no stabilisation. So I've decided to try this out with my DJI Mobile 2 (which was gathering dust), should give me some nice stable 4k HDR video IF it works. But also wider angle stable 4k if required, the rock steady is superb when not in HDR mode, but cuts off the unwanted bits of the image round the sides, which may be undesirable at times.
Bought previously (11th June 2019), upgraded firmware via MIMO, all successfully working at V01.03.00.10. Checked that Rock Steady was being displayed. And have taken a few videos and photos today. All seemed fine until I noticed this evening that RS was no longer on offer, EIS was now being displayed on screen.
This evening I downloaded firmware to micro SD, but presumably because the camera is at latest build the file on the sd card does not get used to refresh firmware as I'd hoped it might.
I've tried powering off & on, factory reset doesn't seem to be an option although I tried variuos button combinations, but to no avail.
Has anybody else seen this at all, any way to force firmware refresh ?
Edit:- When I try to load the .bin file manually in the micro SD card it returns the followin as a .txt file :-
[00002135]
========== 2019.06.13 16:04:43 remo-con disconnect======
[00002144]Packet: OSMO_ACTION_FW_V01.03.00.10.bin [00002147]
I 'assume' this means it hasn't attempted to update as it is already at that build level.
