Mavic 2 Pro Setting Nobody Talks About
744 7 2019-6-12
Henrik Olsen
Flight distance : 2042385 ft
Denmark
In this video, I show how EXP or EXPO settings will help you make your Mavic 2 Pro or Mavic 2 Zoom footage a lot smoother if used correctly. This tip is not only for Mavic 2 but applies to another DJI drones that are controlled by a remote, with the exception of DJI Spark
2019-6-12
AJC-W
Flight distance : 13838848 ft
Thanks a lot for sharing
2019-6-12
JJB*
Flight distance : 12225059 ft
Hi Henrik,
Great video again, but i do not onderstand your explanation at 3m9s ; attitude and yaw movement.
Hope you can explain in better for me ?
cheers
JJB
2019-6-13
Tollytastic
Flight distance : 30932 ft
What a great video !!! I was about to post asking what effect changing stick sensitivity will have when changing modes, now I know. I am also very pleased to hear that we have Exponential (well done DJI) as being from an RC aircraft and helicopter background this is something which for me is essential as it give you the opportunity to slow down stick response in the centre but still leaves you full control movement on larger stick movements for when its needed.
I would make only one comment and that is if you are changing stick sensitivity and EXP settings then do it a little at a time and in stages as large changes can give big surprised on the sticks.
Fantastic video and thanks for posting it
2019-6-13
Montfrooij
Flight distance : 2560453 ft
Good video!
2019-6-13
Henrik Olsen
Denmark
JJB* Posted at 6-13 00:31
Hi Henrik,
I can try, attitude is how the aircraft reacts to your stick response. I normally don't touch that and leave it at 100.  Yaw Movement Limit, you can limit the maximum speed of the yaw (rotation around own axis slower)
Thanks
2019-6-13
JJB*
Henrik Olsen Posted at 6-13 03:28
Thanks
Hi,
Thanks, i will leave attitiude at 100, do not understand it.
Yaw speed limiting make sense, thanks for that!
cheers
JJB
2019-6-13
DJI Gamora
Hi, Thanks for sharing this interesting video that you created about settings of the DJI Mavic 2 Series. This will really help us a lot especially our DJI co-pilots that are looking for settings to set up their drones. Thank you for your continued support. Cheers!
2019-6-13
