S-e-ven
Flight distance : 5910961 ft
Thailand
Dronin Posted at 7-9 13:32
interesting, I did not know there was a warranty. So a 6 month warranty is a good hint. I got more than a year out of them so I guess I need to budget that cost into flying. $90 for 60 full charges... $1.50 a flight.. that is a pretty economical hobby..
and maybe you know..... when you charge a battery from 50%-100% is it true that only registers as 1/2 charge??
It seems like the batts adding together several semi charges to one full charges.
You can check on that in the app yourself, I mark it //// for every charge I do, and despite that I fly mostly to almost empty, every now and then, when checking the cycles in the app, I have a lesser count.
And that the app tells "good": The app doesnt see the belly. It looks like, you still can get the power out. Perhaps a minute or two less and not flying them that much down and not in sport all the flight any longer. Just the belly will once eject the batt midair , without a batt safety , eventually! (I got some, the pregnant batts are the one with the short locks, till now.)
But I mostly use the old batteries now for data transfer on trips or for calibration and stuff like that, only. Because I like my Sparks a lot! ;-) |
