Phantom 2 Vision + Gimbal problem
1118 1 2015-6-7
panling.liu
Singapore
PROBLEM: The gimbal starts up, but the camera is not level.
http://www.rotorpixel.com/troubleshooting/
The link above is the solutions to fix the problem.
But for point 4:  Press the small black button on the back of the gimbal once quickly (do not hold it down... this will reset the board completely).
I can't find the small black button,
can someone give some guidance ?
Thanks.
Regards
2015-6-7
roy
I do not think that information is for the vision + onboard camera. Go to YouTube and search on Phantom 2 vision + gimbal and look at those videos. They show how and you can see that it is the same camera gimbal as you have.  Now are you talking about when you power on the Phantom that the camera starts up and is tilted down on about a 45 degrees then that is the normal. We have to bring it back to level with the controls. If it is tilted to the left or the right and is off level that way then it is a potentiometer issue and the video will show how to fix that. Hope this helps.
2015-6-8
