Height Restricted
Shawno5
Flight distance : 1267694 ft
Hi all, Went to fly the work owned P4A today and at the top of the screen it says that maxiam height 150m and flashing yellow. I have not done any updates since the last flight so Im not sure whats going on.
I can go above the 120m with out the drone stopping because it says maxiam 150m, i am allowed to go above the 120m with the work drone, but i have to go above that height and yes i have all the paper work to go above the height limit.
Please help
Shawn
2019-6-13
DJI Gamora
Hi, there. We do apologize for the inconvenience. Can you please try to fly your drone in a different location for us to check if the issue will still persist? Also, if you are restricted on that specific location I will highly advise you to contact our designated department at flysafe@dji.com. will also post a link wherein you can check if that location is in the no-fly zone area. Please keep us posted. Thank you for your kind and understanding. Cheers!
https://www.dji.com/flysafe/geo-map
2019-6-14
BagoDJIoperator84
Flight distance : 1077608 ft
Trinidad and Tobago
Where are you trying to fly your drone? Check you setting and see what is your max height is set too?
2019-6-14
