RedHotPoker
Flight distance : 165105 ft
At home, with wifi enabled, Go into the Go app, and be sure Cache Maps In Background is turned on.
Have your drone turned on, when you do this? Now open the app and bring up Map View.
Once you have everything running, pinch squeeze the map, and scroll to your proposed flying area.
Zoom in, to the flight area, and scroll the map around, well beyond your planned flight zone.
Now once you shut everything off, the proper map should be available, when you arrive at the flight area, with no wifi access.
It’s not a perfect system, and is not infallible but it works most of the time.
RedHotPoker |
