Tello wifi not working after firmware update
10832 7 2019-6-17
fans032f1fc6
Flight distance : 502858 ft
Helo, Hope you can help me
I just updated my tello  to the last firmware
My tello has a month and worked perfectly
I updated to try get 30m high
After updated , the Movil disconnected from the WiFi and I can’t see the WiFi any more
I tried with other Movil but can’t see the WiFi
I tried the restart WiFi by pressing 10 secs the on button but again can’t see WiFi
I also tried to restart WiFi by turning one eating for yellow light blink and press the button again 8 seconds but didn’t work
I also tried to find the WiFi setting the airplane mode and didn’t work ,
I tried all convinations of all those métodos but don’t work any
Please I need your help , this yellow is really new (1 month) I was really happy with it.
2019-6-17
RYZE
Super Moderator
Dear customer,
We are so sorry to reply you late. In regard to your problem, please try to re-upgrade the firmware. Please press and hold the Power Button for 5 seconds when the Tello is powered off and release it when the green indicator turns off. Then the indicator will pulse red. Connect to the Tello's Wi-Fi and go to Setting - more - firmware version to upgrade the firmware again. After that, please confirm if the issue still persists.
If the issue still persists, please contact us via support@ryzerobotics.com.
I hope my answer can help you. Thanks a lot.
2019-6-20
VRooMAR
Flight distance : 86129 ft
Resetting Tello works mostly in such cases. Keep power button pressed for 5 secs.
2019-7-14
djiuser_jLxcVpxfnmJ3
Indonesia
RYZE Posted at 6-20 17:26
Dear customer,
If the issue still persists, please contact us via .
I've already do that. Read more article about how to solve it, but i didnt found it.
It just happen more and more for Tello user in Indonesia,
We need step to solve this problem and use our tello againt
Please.
2019-12-18
RYZE
Super Moderator
djiuser_jLxcVpxfnmJ3 Posted at 12-18 05:11
Dear customer, we are so apology that you face this issue. But in regard to this problem, it needs to be repaired. So if convenience, please connect us via support@ryzerobotics.com. Our colleague will provide you the guideline to help you to send your Tello to our facility. Thanks a lot.
2019-12-24
Dr. Papa
Greece
I had the same problem. Drone was showing sensor error and was not calibrating. I contacted support but they only told me they did only told me to bring it back to repair.
I found a solution by myself which is really simple: just reset the drone. Power on, press the power button for 8 seconds, reinstall the app and everything gets back to normal. Hope this works for you too.
2020-3-1
djiuser_x8CyOsXAOpFI
Israel
RYZE Posted at 2019-6-20 17:26
Dear customer,
Hi i need help my tello have no firmware and loader..i try to update it many times it say successful but when i check the firmware and loader is empty
2020-8-2
Samuel Assunccedilatildeo
Brazil
djiuser_x8CyOsXAOpFI Posted at 2020-8-2 19:39
im facing this same problem, have u solved it?
2021-4-29
