AntDX316
Flight distance : 3394731 ft
Aardvark Posted at 6-18 09:37
Well, it says Phantom 4, it means Phantom 4, plain and simple English.
And if you knew anything at all about the aircraft you fly then you would realize this, also given that the RC firmware quoted (V1.9.3.0) is the build of the GL300C as used on the Phantom 4, and not that used by the Phantom 4 Pro (&V2), nor the Phantom 4 Advanced RC units.
Well, the fact they are even upgrading the first P4 must be a good sign. The P4P V2.0 is far from garbage. Discontinued is crazy. The quality of the photos is better than the Mavic 2 Pro. They probably realized the design of the M2 Pro camera being bad, saving lots of money by discontinuing the production and just selling the M2 Pro design as it has More profits. In the end, the consumer and clients get screwed who don't know. It makes me look better as I can provide Sharper images w/ no distortion. : )
P4P V2.0 pretty much is the best setup you can get unless you get the Inspire 2 with X5R or better but then the image quality is nearly the same. The X7 is the best then cost $15k but not that out there. Going from the Spark to an M2Z is out there. Anything just takes Far too much work. I can get up and running in pretty much no-time. |
