Kuky74
Romania
Hello,
I bought a Ronin-s Essentials Kit and I paired with a Sony A7 III. Now I want to buy a cable to atleast be able to start/stop camera from the gimbal.
At the time of this post the last firmware for Ronin-S is v1.8.0.70 and for camera is 3.01 so what I am asking takes this into consideration.
From what I read using MCC-C cable there are two huge problems. You have to set the USB connection to PC Remote but this disables IBIS (in-body stabilisation) and HDMI output. Probably a camera limitation. But this makes this cable almost useless. You never want to disable IBIS, it makes a big difference even when using camera on gimbal. See here: https://www.youtube.com/watch?v=Yc_aDB7VWpE
In the compatibility list there is no clear mention of the behaviour of the MCC-multi cable.
So my questions are:
1. Does the MCC-multi cable also disables IBIS?
2. Does the MCC-multi cable also disables HDMI Output?
3. Is there any limitation I should be aware using the MCC-multi cable?
Thank you,
Cristian
