Rode Videomic Connection
1088 10 2019-6-23
key1979
Help...I am not good at this at all.  I've been trying to hook up a rode videomic with my Osmo Pocket but I can't figure it out.  I've searched through a ton of youtube videos and it won't work.  How do I do it?
2019-6-23
DJI Stephen
Hello and good day key1979. I am sorry for the trouble and thank you for reaching out. I hope that you will get the best information from our valued DJI members who uses the Rode Videomicrophone on there DJI Osmo Pocket. Thank you.
2019-6-23
Ray-CubeAce
Hi.
Unless you have the DJI audio adaptor you won't get any mic to work with the Osmo Pocket.
If you do have the DJI audio adaptor then I would suggest not using a powered mic unless it has a +20dbm gain switch on it. Do not use anything that has a TRRS connector but uses a TRS one. The mic should preferably be able to take a 3v to a 5v power supply and have a good SNR.
2019-6-23
key1979
Ray-CubeAce Posted at 6-23 14:29
Hi.
I bought the DJI audio adapter but I am not sure what cord to use to connect it to the Osmo Pocket.  The cord I am using doesn't work.  What is the correct cord to make it work? Thanks!
2019-6-25
Ray-CubeAce
key1979 Posted at 6-25 10:41
Sorry but I don't quite understand what you mean by 'cord'. The audio adaptor plugs directly into the base of the Osmo Pocket. From there the mic must have a 3.5mm stereo jack plug with just a tip (T) ring (R) and shield (S) configuration. 3.5mm jacks with two rings can't be used.
[EDIT / Added]
Sorry, I just noticed the title.
If it is the standard Rhode video mic, it doesn't seem to have a powerful enough output to work well with the audio adaptor. The Rhode video mic Pro will work at the +20db gain setting with the Osmo Pocket setting at auto.
2019-6-25
col4bin
Flight distance : 86224 ft
Hi.
Can you recommend a good general purpose mic that will not break the bank?  Thank you in advance.
2019-6-25
Ray-CubeAce
col4bin Posted at 6-25 17:28
There have been a few recommendations on the forum with various mics that people say have worked. I'm currently evaluating a Saramonic SR-XM1 which is about £20 from Amazon. It's small, mono, the top end doesn't quite match the internal mics and I have to be careful not to introduce handling noises when recording but with the right windshield I can cut down some wind noise and front to rear noise rejection is better than the internal mics. Maybe a bit too directional depending on the requirements of the shoot.
I will be building my own using capsules recommended by David Harry on this forum for use later as I've yet to find a mic small enough to go with the Osmo Pocket that fits both my size and performance requirements. My Rhode Video Pro mic works ok but is a bit too large and produces a very slight hiss when very quiet.
2019-6-26
key1979
Ray-CubeAce Posted at 6-26 06:13
Thanks for the info...I have the DJI adapter attached to the Osmo Pocket, a 3.5MM TRS jack attached to a Rode Videomic Me.  For some reason this setup won't work for me.  I am getting no audio at all in my videos.
2019-6-26
Ray-CubeAce
key1979 Posted at 6-26 10:03
Doesn't the Rhode VideoMic ME have a TRRS connector? I can't find one listed with a TRS connector.
Don't use TRRS terminated mics with the Osmo Audio adapter. They will not work. They may damage the audio adapter.
2019-6-26
key1979
I tried the trrs to trs connector too and that still didn't work.
2019-6-26
Ray-CubeAce
key1979 Posted at 6-26 12:43
No, they won't. Those adapters are meant for headphone conversion, not microphones. What normally happens is the converter shorts the mic out.
2019-6-26
