Changing props - anything else to do?
1193 9 2019-6-26
Dean01
Flight distance : 15513100 ft
South Africa
Hi all,
had a small crash and damaged two props of original type.
My only spares are a set of "quiet props" which i will change over to.
Can i just swop them out and continue flying OR is there any settings in the app i must alter to accommodate the new props?
2019-6-26
Stryker03
Flight distance : 206345 ft
I do not believe there is any change in the App required.  But if you are changing styles, or types of props I would recommend you change all four, and not just the damaged ones.
2019-6-26
Dean01
South Africa
Stryker03 Posted at 6-26 00:32
thanks stryker - i have a full set and will change all four
2019-6-26
DJI Tony
Hi, we're sorry for the mishap that happens to your drone. It's recommended to change the propellers if it is scratched, bent, or damaged, replace it immediately. It is recommended to replace them at least every three months. For additional information, if you will use a different type of propellers, it recommended replacing all old propellers. Should you have further concerns, please let us know. Thank you for continued support.
2019-6-26
GhostWolf010
Flight distance : 1118323 ft
You dont have to change anything, I switched from normal to silent without any adaptations, and it perfectly worked.
2019-6-26
Dean01
South Africa
GhostWolf010 Posted at 6-26 10:20
thanks ghost
2019-6-26
fans19db8551
Flight distance : 352851 ft
Singapore
nothing to change. just be aware that the low noise props are less effective in fighting high wind. i'm not sure exactly why. perhaps because it's more flexible. just a fyi
2019-6-29
Dean01
South Africa
fans19db8551 Posted at 6-29 05:21
thanks for that - i fly in the wind a lot of so i appreciate that heads up info.
2019-7-12
DAFlys
Make sure you check for debris in the top of the motor when you remove the props.  I damaged a prop once and part of the mounting sheered off into the motor.  It came out no problem but worth checking for.
2019-7-12
Woe
Flight distance : 4129268 ft
Since you crashed after changing the props I would also do an IMU calibration as well.
2019-7-12
