Battery is going to die before firmware update finishes, please help
1768 3 2019-6-26
dan_m
Hi all, first post here. I was prompted to update the firmware on my Mavic Pro, and began the process about 40 minutes ago. It has only progressed to 24% at the moment—my internet connection is working as it normally does, but this update is installing incredibly slow. I am almost positive that both the drone battery and the controller battery are going to die before it completes. I know things can get messed up from interrupted updatess, does anyone have some advice?
2019-6-26
DJI Tony
Hi, we're sorry for the inconvenience that it causes. You may consider updating the firmware using the DJI Assistant 2 to see if there will be changes with the progress. You may refer to the link below for downloading the DJI Assistant 2 and video tutorial. Kindly keep us posted on the latest progress. Thank you for your support.
https://www.dji.com/mavic/info#downloads
2019-6-26
dan_m
Should I quit the current update?
2019-6-26
AJC-W
Flight distance : 13838848 ft
dan_m Posted at 6-26 16:08
I would - firmware updates should take no more than 20 minutes and are typically around 10.
2019-6-26
