S-e-ven
Flight distance : 5910961 ft
Thailand
Ok, you totally misapprehend my questions, my bad, perhaps ;-)
I am not interest in the past, I just wanna know from now!
How long have you waited, in the air, for GPS sats, how many has your bird seen, till you switched it off, again?
Did it see any?
You need about 10 (ten) shown locked, to get the green GPS Mode running!
And that is b/c DJI is using GPS AND Glonass at the same time, 5 or 6 from ONE of this Systems are needed, to get you a stabil 3 dimension position for flying a drone.
You have tried it somewhere else, now?
Just start the bird somewhere and check how (if any) satellites it sees!
As long it sees satellites, "there is hope"
It may just not have been easy enought, to see enough of them, that day., these days
"I did go out today after downgrading the firmware. Now I am also getting the GEO location of airport. Fly safe notification on top of the Max altitude notification."
You may get them because the app gets them of the A-GPS in your device and from the "weak' GPS positioning from the Bird with just not enough GPS recognized for GPS flight.
How about you upload a flight record of one of your "max flight altitude reached" flights?
https://www.phantomhelp.com/logviewer/upload/
