Sean-newbie
Flight distance : 15997 ft
I got a 2nd hand joystick assembly and after fitting it and calibrating the sticks, success.
Then I dropped a &&&&88888.
I had only used a few screws, loosely tighten, to hold things in place for testing. Whilst reassembling it correctly i.e. adding the remaining screws and nipping them up, the controller slipped. I made a grab for it, BAD MISTAKE. The USB ribbon cable got snagged and ripped off the motherboard along with its connector, the latter seems to have taken some tracks with it. I'd probably have been better off letting the controller 'drop'.
So I now have a controller with no USB connection nor working C1 & C2 switches, ho hum, and there is absolutely no chance of my being able to repair that damage to the motherboard.
Fortunately both the drone and controller are 'spares'.
I expected the damage would have killed the MB but after making sure the loose sections of track were removed i.e not shorting to one another, the controller successfully boots and controls its drone, I was quite surprised by that. |
