Sean-newbie
Ta Mark, going now.
Update.
I tried the flow chart but my situation doesn't follow it that well as I have no control over the camera and trying to take a photo via the controller fails or at least there is no image on the mSD card.
However I came across a video of the dismantling of the camera/gimbal and it didn't look too bad wrt the motherboard (MB) and camera sensor board so I swapped MB's and the suspect camera gives an image.
The suspect MB did not give an image with a good camera. The MB contacts on the ribbion cable had some white marks on them and this was cleaned off, to no effect.
I see one screw which might hold the MB into its housing but the MB doesn't seem to want to move when that screw is removed.
Does anyone know if the MB is 'stuck down' in its housing?
I see no obvious damage on the MB but given the TINY size of some of the components..............
Is it possible to clean the contacts inside the ribbon cable connectors with, say, a piece of paper being pushed into and pulled out of the ribbon cable connectors or would this be too aggresive?
Ta
