DJI Tony
Hi, thanks for the inquiry. Regarding the channel settings for the Mavic 2's Wi-Fi image transmission. channel settings can be set in the app. Under Transmission settings, you can select auto mode and manual mode. After the manual mode is selected, you can set the channel as required. Channel settings can only be set before the flight. Regarding the FCC and CE, please kindly note that users cannot switch between the FCC and CE manually. The remote controller will enable FCC or CE mode based on your location in accordance with local laws and regulations. Hope that this information would clarify your query. Thank you for your support. |
